Car Repair Questions Diagrams Auto Manuals Auto Repair Estimates Automotive Repair Diagnostic Trouble Codes
You can run low octane fuel in cars that are 1996 and newer but you will not receive the expected fuel mileage as you would get with higher octane fuel. And if your car has a higher compression ratio you can cause damage to the engine no matter the year of the vehicle.
There is a misconception in the world that high octane fuel will make your car go faster or run better. This is not true. The octane rating only rates the fuel’s resistance to engine knocking.
Knocking or pinging is a sound that an engine makes when the air-fuel mixture in the combustion chambers ignites too early. (Also known as pre-detonation). Although slight knocking or pinging won’t damage your engine, loud knocking can cause damage and should not be allowed to continue. It can actually burn a hole right through the piston over time. The solution is to use a high octane fuel, which is actually more difficult to ignite, despite the misconception that high octane fuel is more powerful. When the fuel is more difficult to burn, early ignition is eliminated, and with it the knocking or pinging.
The octane level required by an engine is determined by its compression ratio: higher-compression engines require higher-octane fuel. For example, a basic sedan generally only requires the standard octane fuel offered at gas stations, while a high-performance sports car or race car may require a high octane fuel. The owner’s manual lists information on the type of fuel you should use in your car. The reason behind this, the more advanced the engine timing can be, the more power the engine can produce. In most engines today the timing is controlled by the computer that receives a signal from a knock sensor. The engine will only advance the engine timing up to the point of knocking. So if you raise this point with higher octane, then the computer will allow the engine timing to advance further than using lower octane thus delivering more power.
Gas stations typically offer three different octane levels of fuel: regular, mid-grade, and premium. The regular grade generally has the octane level required by most cars, and mid-grade and premium are each a step up. Then, of course, there is the super high octane fuel available at race tracks, which is designed for the extremely high compression ratios that race car engines have. Pretty much all of the fuel grades commercially available have cleaning additives in them, so you need not choose a high octane fuel with the idea that it will clean your engine better.
divider
Top Categories
Serpentine Belt Routing Diagrams
Ask a Mechanic
Free Insurance Quotes
Car Owners Manuals
Auto Wiring Diagrams
Auto Repair Manuals
Hybrid Cars
Nut & Bolt Measuring Charts
Mechanic's Lien Form
Manufacturer
Acura
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Datsun
Dodge
Ford
GEO
GMC
Honda
Hyundai
Infiniti
Isuzu
Jaguar
Jeep
Kia
Lexus
Lincoln
Mazda
Mercedes
Mercury
Mitsubishi
Nissan
Oldsmobile
Plymouth
Pontiac
SAAB
Saturn
Scion
Subaru
Suzuki
Toyota
VW
Top Repair
Air Conditioning Troubleshooting
Blown Head Gasket
Brakes
Auto Repair
Engine Overheating
Engine Sensors
Struts
Hub Bearings
No Start Diagnostics
Transmission
