Trouble Codes › Chrysler OBD Trouble Codes
Full list of OBD I Diagnostic Trouble Codes for your '88 - '95 Chrysler. If your Check engine light is on you may have a serious problem. Scan your codes and follow the chart to determine what the code means. Some shops will scan your codes for free. Autozone is one place that will give you the code number.
How to Check Chrysler codes without a scantool
  • Start with the ignition off. Within five seconds, switch the key on, off, on, off, on. (On is *not* start!)
  • The "check engine" light will flash. Count the flashes Each code is a two digit code, so a (for example) 23 would be FLASH FLASH (pause) FLASH FLASH FLASH (long pause)
  • It will never flash more than 9 times, watch for pauses!
  • 55 is end of codes - it's normal. Before you call your dealer or mechanic, consider that the blink-spacing is not always perfectly uniform, so if you see 23 23, it's probably just a single 55. (Codes are not repeated.)
33 is normal on earlier models if you don't have air conditioning.
  • John McGuire wrote: "The older Vipers will blink out diag codes with four off/on key turns. They removed the capability starting in... I think 2000, at any rate I know my 2001 requires a computer to check the codes.
  • On some models (such as a 1995 Neon), when the check engine light goes on, you may be able to get the codes simply by putting in the key and moving it to the RUN position; the light will blink out the codes by itself.
  • Please note that some codes are NOT included below, this is not a complete listing, but it IS very close to complete. It stems from a list posted on the Mopar Mailing List, but many modifications have been made.
  • * Activates Power Limited/Check Engine light on some models.
IMPORTANT. Codes may be different for newer vehicles starting in the late 1990s. See the earlier section.
  • 11 No ignition reference signal detected during cranking (bad Hall effect) OR timing belt skipped one or more teeth; OR loss of either camshaft or crankshaft position sensor. Can cause the engine to stop working entirely with no limp-home mode.
  • 12 Battery or computer recently disconnected
  • 13* MAP sensor or vacuum line may not be working
  • 14* MAP sensor voltage below .16V or over 4.96V
  • 15 No speed/distance sensor signal
  • 16* Loss of battery voltage detected with engine running
  • 17 Engine stays cool too long (bad thermostat or coolant sensor?)
    • 17 (1985 turbo only): knock sensor circuit
  • 21 Oxygen sensor signal doesn't change (stays at 4.3-4.5V). Probably bad oxygen sensor
  • 22* Coolant sensor signal out of range - May have been disconnected to set timing
  • 23* Incoming air temperature sensor may be bad
  • 24* Throttle position sensor over 4.96V (SEE NOTE #3)
  • 25 Automatic Idle Speed (AIS) motor driver circuit shorted or target idle not reached, vacuum leak found
  • 26 Peak injector circuit voltage has not been reached (need to check computer signals, voltage reg, injectors) (SEE NOTE #4 BELOW)
  • 27 Injector circuit isn't switching when it's told to (TBI)
    OR (MPI) injector circuit #1 not switching right
    OR (turbo) injector circuit #2 not switching right
    OR (all 1990-) injector output driver not responding
    - check computer, connections
  • 31 Bad evaporator purge solenoid circuit or driver
  • 32 (1984 only) power loss/limited lamp or circuit
  • 32 EGR gases not working (1988) - check vacuum, valve
  • 32 (1990-92, all but Turbo) computer didn't see change in air/'fuel ratio when EGR activated - check valve, vacuum lines, and EGR electrical
  • 33 Air conditioning clutch relay circuit open or shorted (may be in the wide-open-throttle cutoff circuit)
  • 34 (1984-86) EGR solenoid circuit shorted or open
  • 34 (1987-1991) speed control shorted or open
  • 35 Cooling fan relay circuit open or shorted
  • 35 (trucks) idle switch motor fault - check connections
  • 36 (turbo) Wastegate control circuit open or shorted
  • 36 (3.9/5.2 RWD) solenoid coil circuit (air switching)
  • 36 (Turbo IV) #3 Vent Solenoid open/short
  • 37 Shift indicator light failure, 5-speed
    OR
    part throttle lock/unlock solenoid driver circuit (87-89)
    OR
    solenoid coil circuit (85-89 Turbo I-IV)
    OR
    Trans temperature sensor voltage low (1995 and on; see NOTE 2)
  • 41* Alternator field control circuit open or shorted
  • 42 Automatic shutdown relay circuit open or shorted
  • 42 Fuel pump relay control circuit
  • 42 Fuel level unit - no change over miles
    OR
  • 42 Z1 voltage missing when autoshutdown circuit energized (SEE NOTE #6)
  • 43 Peak primary coil current not achieved with max dwell time
    OR
  • 43 Cylinder misfire
    OR
  • 43 Problem in power module to logic module interface
  • 44 No FJ2 voltage present at logic board
    OR
  • 44 Logic module self-diagnostics indicate problem
    OR
  • 44 Battery temperature out of range (see Note #1!)
  • 45 Turbo boost limit exceeded (engine was shut down by logic module)
  • 46* Battery voltage too high during charging or charging system voltage too low
  • 47 Battery voltage too low and alternator output too low
  • 51 Oxygen sensor stuck at lean position (Bob Lincoln wrote: may be tripped by a bad MAP sensor system causing a rich condition, and the O2 sensor trying to compensate. The O2 sensor may still be good. The MAP assembly consists of two pieces, the valve and the vacuum transducer (round plastic unit with cylinder on top and both electrical and vacuum connections) - If you get hot rough idle and stalling, especially on deceleration, accompanied by flooded engine and difficulty restarting, that can be a bad MAP sensor causing the O2 sensor to try to compensate. If you get poor cold driveability, stumbling and bucking, and acceptable warm driving with poor gas mileage (a drop of 10 mpg or more), that is usually the O2 sensor. [Webmaster note: MAP sensors seem to die regularly.]
OR
  • 51 Internal logic module fault ('84 turbo only).
  • 52 Oxygen sensor stuck at rich position (SEE NOTE #5!)
    OR
  • 52 Internal logic module fault ('84 turbo only)
  • 53 Logic module internal problem
  • 54 No sync pickup signal during engine rotation (turbo only)
    OR
  • 54 Internal logic module fault ('84 turbo only) - or camshaft sensor/distributor timing (7)
  • 55 End of codes
  • 61 "Baro" sensor open or shorted
  • 62 EMR mileage cannot be stored in EEPROM
  • 62 PCM failure SRI mile not stored
  • 63 Controller cannot write to EEPROM
  • 64 Catalytic converter efficiency failure
  • 65 Power steering switch failure
  • 88 Start of test (not usually given, don't expect it)
Chrysler Trouble Codes
divider
