Free Auto Mechanic
It is important that use use all safety precautions when working on your car, truck or SUV .
    In this section you will find complete step by step instructions for properly replacing the front wheel hub bearing assembly. If you follow these steps you are assured to make the front wheel hub bearing removal and replacement as easy as possible.
Brake Rotors     Master Cylinder     Vacuum Booster     Caliper     Wheel Cylinder     Disc Brakes      Drum Brakes     ABS System
Step 1. You will need to jack up the car and remove the front wheels and brakes to gain access to the front hub bearing. Click on any image for a close up look.
Remove Caliper Bolts
Step 2. Remove the two brake caliper bolts from top and bottom.
Remove Front Brake Caliper
Step 3. Remove the Caliper. It may be necessary to use a screwdriver to pry the caliper loose allowing it to be removed easily.
Remove Brake Pads
Step 4. Remove the Front Brake Pads. They will slide off from each side.
Remove Caliper Mounting Bracket Bolts
Step 5. Remove the two caliper mounting bracket bolts. You may need to use an extension to break these bolts free.
Step 6. Remove the Caliper Mounting Bracket
Remove Front Brake Rotor
Step 7. Remove Front Brake Rotor. Should the rotor become stuck, you may need to use a Large Hammer to jar it loose.
Hub Bearing Removal
Step 8. Remove the Center Hub Bearing Retaining Nut and the three retaining bolts from the back of the hub bearing.
Loosen axle shaft
Step 9. Use an Air Hammer to loosen the axle shaft from the Hub Bearing assembly.
Remove Hub Bearing
Step 10. Make sure to disconnect the ABS Sensor wire and then remove the hub bearing.
Hub bearing bolts
Step 11. Slide the new Hub bearing Assembly on and install the three retaining bolts from the rear and tighten. Make sure if there was a thin spacer that it is installed also.
Hub Bearing Nut
Step 12. Install the center Nut, Tighten and reconnect the ABS wire connector if equipped.
Install New Rotor
Step 13. Install the Rotor over the wheel studs.
Install Caliper Mounting Bracket
Step 14. Install caliper mounting bracket using the two bolts you removed in Step 5.
Secure Bracket
Step 15. You may want to apply a small amount of "blue" LockTite to the bolts before tightening them.
Lubricate New Pads
Step 16. Apply a small amount of non-drying brake silicon to the back of the brake pads. This will help reduce noise that is caused by vibration.
Install New Brake Pads
Step 17. Install the brake pads into the sides of the caliper mounting bracket. Be sure to wipe off any lubricant that might have gotten on the rotors.
Compress Caliper piston/s
Step 18. Compress the caliper pistons. Here we use a caliper compressor but a c-clamp or equivalent can also be used.
Install Caliper
Step 19. Install the Caliper. Slide the caliper over the pads and align the caliper mounting holes and install the two bolts removed in Step 2.
Attach the wheels and pump the brake pedal before you test drive it!
Ask Now!
Content ©Copyright 2006 - 2009 by FreeAutoMechanic.com. All Rights Reserved | Privacy Policy | Site Map | User Agreement | Search | Resources | Twitter
