where is the ignition sensor located on an 1989 olds delta 88
Auto Repair Questions and Answers – Auto Repair Help – Ask A Question – Freeautomechanic.com
10 Nov, 2009 Auto Repair Questions, Oldsmobile
Since 2006 Copyright Freeautomechanic.com
The Crankshaft Position (CKP) sensor is mounted to the front left side of the timing chain cover.
The Camshaft Position Sensor is located Just Below the Water Pump.
First thing I would do is check the codes Here is How: http://www.freeautomechanic.com/diagnostictroblecodes5.html
