Dies when Im driving it and wont start until a few hours. Will be ok for a few days and then does the same thing again.
1998 Ford Explorer
Keywords:No Start
With an intermittant no start such as this it will be difficult to determine the cause. When it has died and will not start, you will need to check for spark and fuel to see which one is missing and concentrate on that part of the system.
http://www.freeautomechanic.com/nostart.html
A good test would be to have some starting fluid on hand and shoot some in the air filter the next time it dies and see if it starts right back up. If it does, you will know it is fuel related and can concentrate on that system.
