After the AC technician finished AC repairs and recharge, the engine 3.3L stopped running and a gas odor came from somewhere under the vehicle. Inspection of all gas lines showed no leaks. Fuel pump came on, but no fuel pressure present at the injectors. The scan tool showed a circuit problem with the No. 1 cylinder. Fuel filter is okay as well. Still no fuel present at the injector fuel rail.
(QUOTE)but no fuel pressure present at the injectors.
(Quote)Still no fuel present at the injector fuel rail.
Check for blown fuses, circuit breakers, or fusible links. Confirm an operational ASD relay.
