I have a 1978 dodge long box that when I try to reverse it chatters real bad .The truck only has 70,000 kmsĀ on it and the original owner said it done it since new . It is a 4 speed manual and I have checked the pinion angle put clamps on the springs changed the tranny mount and engine mounts and clutch and pressure plate . Any ideas?
The first thing that comes to mind is hot spots on the flywheel. Did you have it resurfaced when you replaced the clutch and pressure plate?
