Home » Car Questions » Brake Line Compression Fittings
brake line compression fittingsAre compression fittings on brake lines legal in New York State ?
Brake Line Compression Fittings in New York State
This was an approved quality repair up until a few years ago. Now New York State department of motor vehicle does not recognize that has a quality repair. And compression fittings are now a failure on New York State inspections. So even though it was acceptable a few years ago now is not. If you’d like a copy of this from the department of motor vehicle you can go to https://dmv.ny.gov/
The brass AGS brake line compression fittings state right on the package that they are “Not for brake lines”.
Dorman offers a High pressure compression union fitting constructed of high-quality materials for long-lasting durability. However, Not recommended for hydraulic brake systems.
high compression union fitting brake line
I have used brake line compression fittings many times over the past 20+ years. And have found the brake line itself tends to rust through in other areas before any issues from the use of the compression fitting as a repair.
