Free Auto Mechanic
OBD II Trouble Codes from P300 through P0399
PO300 - PO399 Numbered Code Identification Chart
 P0300 Random/Multiple Cylinder Misfire Detected
 P0301 Cylinder 1 Misfire Detected
 P0302 Cylinder 2 Misfire Detected
 P0303 Cylinder 3 Misfire Detected
 P0304 Cylinder 4 Misfire Detected
 P0305 Cylinder 5 Misfire Detected
 P0306 Cylinder 6 Misfire Detected
 P0307 Cylinder 7 Misfire Detected
 P0308 Cylinder 8 Misfire Detected
 P0309 Cylinder 9 Misfire Detected
 P0310 Cylinder 10 Misfire Detected
 P0311 Cylinder 11 Misfire Detected
 P0312 Cylinder 12 Misfire Detected
 P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
 P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
 P0322 Ignition/Distributor Engine Speed Input Circuit No Signal
 P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
 P0325 Knock Sensor 1 Circuit Malfunction (Bank 1 or Single Sensor)
  P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
 P0327 Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor)
 P0328 Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor)
 P0329 Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor)
 P0330 Knock Sensor 2 Circuit Malfunction (Bank 2)
 P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)
 P0332 Knock Sensor 2 Circuit Low Input (Bank 2)
 P0333 Knock Sensor 2 Circuit High Input (Bank 2)
 P0334 Knock Sensor 2 Circuit Intermittent (Bank 2)
 P0335 Crankshaft Position Sensor A Circuit Malfunction
 P0336 Crankshaft Position Sensor A Circuit Range/Performance
 P0337 Crankshaft Position Sensor A Circuit Low Input
 P0338 Crankshaft Position Sensor A Circuit High Input
 P0340 Camshaft Position Sensor Circuit Malfunction
 P0341 Camshaft Position Sensor Circuit Range/Performance
 P0342 Camshaft Position Sensor Circuit Low Input
 P0343 Camshaft Position Sensor Circuit High Input
 P0344 Camshaft Position Sensor Circuit Intermittent
 P0350 Ignition Coil Primary/Secondary Circuit Malfunction
 P0352 Ignition Coil B Primary/Secondary Circuit Malfunction
 P0353 Ignition Coil C Primary/Secondary Circuit Malfunction
 P0354 Ignition Coil D Primary/Secondary Circuit Malfunction
 P0355 Ignition Coil E Primary/Secondary Circuit Malfunction
 P0356 Ignition Coil F Primary/Secondary Circuit Malfunction
 P0357 Ignition Coil G Primary/Secondary Circuit Malfunction
 P0358 Ignition Coil H Primary/Secondary Circuit Malfunction
 P0360 Ignition Coil J Primary/Secondary Circuit Malfunction
 P0361 Ignition Coil K Primary/Secondary Circuit Malfunction
 P0362 Ignition Coil L Primary/Secondary Circuit Malfunction
 P0370 Timing Reference High Resolution Signal A Malfunction
 P0371 Timing Reference High Resolution Signal A Too Many Pulses
 P0372 Timing Reference High Resolution Signal A Too Few Pulses
 P0373 Timing Reference High Resolution Signal A Intermittent/Erratic Pulses
 P0374 Timing Reference High Resolution Signal A No Pulses
 P0375 Timing Reference High Resolution Signal B Malfunction
 P0376 Timing Reference High Resolution Signal B Too Many Pulses
 P0377 Timing Reference High Resolution Signal B Too Few Pulses
 P0378 Timing Reference High Resolution Signal B Intermittent/Erratic Pulses
 P0379 Timing Reference High Resolution Signal B No Pulses
 P0380 Glow Plug/Heater Circuit "A" Malfunction
 P0381 Glow Plug/Heater Indicator Circuit Malfunction
 P0382 Glow Plug/Heater Circuit "B" Malfunction
 P0385 Crankshaft Position Sensor B Circuit Malfunction
 P0386 Crankshaft Position Sensor B Circuit Range/Performance
 P0387 Crankshaft Position Sensor B Circuit Low Input
 P0388 Crankshaft Position Sensor B Circuit High Input
 P0389
Crankshaft Position Sensor B Circuit Intermittent
Online Auto Repair Manuals On Sale for $10.49 . Get the same information the dealers use that include TSB's, Belt routing, repair procedures, color wiring diagrams and more.
Ask Now!
Content ©Copyright 2006 - 2010 by FreeAutoMechanic.com. All Rights Reserved | Privacy Policy | Site Map | User Agreement | Search | Resources | Twitter
