Free Auto Mechanic
Alarm System / Remote Starter Wiring Installation Charts
    Remote Car Starters are a great addition to any automobile! If you have already purchased your remote car starter, you may want to use the remote starter wiring and installation charts to help make the installation easier on you. If you haven't purchased your remote car starter, we have listed several below that are sure to fit your need from basic to sophisticated.
Air Conditioning Diagnostic Chart      Car Won't Start Diagnostic Chart     Relays and Switches     Testing with a Multi-meter
$57.99 Remote Car Starter
$64.99 Remote Car Engine Starer
Astra 1000 >>  Only $57.99
Two 5-button Code Hopping Long Range Remote With Super Bright Blue LED
Built-In Parking-Light Relay Programmable (+/-)
Pre-wired Super Bright Blue LED, Sensor, and Valet Switch Connectors
Plug-in user programmable Coded Override Switch
Horn Or Ignition 3 (Programmable) (-) Output
Remote Door Locking/Unlocking (-) outputs Programmable Aux. Relay outputs (2nd. Ignition, 2nd. Accessory or 2nd. Starter) Selectable Engine Run Time
Enable or Disable Remote Start in Valet Mode
Over 50 Programmable Features
Galaxy 2000RS SP > $64.99
  • “ScyNet” Network Data Port Accessory Interface and Wizard Software
  • Built-In Parking-Light Relay Programmable (+/-)
  • Pre-wired Super Bright Blue LED, Sensor, and Valet Switch Connectors
  • Plug-in user programmable Coded Override Switch
  • Horn Or Ignition 3 (Programmable) (-) Output
  • Remote Door Locking/Unlocking (-) outputs
  • Passenger Unlock (-) Output
  • Two Auxiliary Channels with Selectable Output Types, (Pulsed, Timed or Latched)
  • Remote Keyless Entry and Accessory Activation Even in Valet Mode
  • Remote-Controlled Courtesy Lighting
  • AutoActivation Upon Locking And Unlocking of Auxiliary 2 Output for Comfort Closure (windows)
  • Smart Remote Trunk Release
  • Turbo Timer
  • Over 50 programmable Features
$910.49
Galaxy 2000RS-2W -1 Remote Starter
•One Carbon Fiber 5-button 2-Way Remote
•One 5-button Long Range Remote W/ Super Bright Blue LED
•Complete remote engine starter module
•Pin Switch
•Wiring harnesses
List Price: $250.00
Our Price: $910.49
You Save $150.01!
$159.00 LCD Remote Starter
Galaxy 2100RS   complete 2 way color LCD remote start system
•One Carbon Fiber 5-button True Color 2-Way LCD Remote
•One 5-button Carbon Fiber Remote W/ Super Bright Blue LED
•Pin Switch
•Wiring harnesses
List Price: $320.0-
Our Price: $144.99
You Save $175.01!
Online Auto Repair Manuals On Sale for $10.49 . Get the same information the dealers use that include TSB's, Belt routing, repair procedures, color wiring diagrams and more.
Ask Now!
Become A Mechanic - Learning all that you can about being an Automotive mechanic, Nascar mechanic or just want to know more about Car repair...
Remote Start Wiring - installation chart with wire colors for a remote start or car alarms
Scan Engine Codes - There are many different types of code readers, this will help you decide which one is right for your application
Compression Test - What is an Engine Compression test and How to perform an engine compression test
Car Repair Manuals - Find Online Auto Repair Manuals that include wiring diagrams, drive belt routing, step by step procedures....
Brake Problems - Diagnose your brake issue and follow the step by step repair procedures
Free Car Videos - Some Free wild and crazy videos for your entertainment.
Scan Engine Light Code - If you have a 1995 or older you can scan codes without a scan tool
Content ©Copyright 2006 - 2010 by FreeAutoMechanic.com. All Rights Reserved | Privacy Policy | Site Map | User Agreement | Search | Resources | Twitter
