Step 2. Remove the Upper Sway Bar link, the Brake line mount and the two Lower Strut Mount Bolts. |
Step 3. Remove the three upper strut mount bolts. |
Step 4. Remove the Old Front Strut. |
Step 6. Securely mount the strut and compress the spring. Then remove the center Strut Nut and remove the old strut, leaving the spring compressed. |
Step 7. Remove rubber snubber, spring gasket and dust shield from old strut and install on new strut before installing the old spring. |
Step 8. Insert New Strut into old compressed strut spring making sure the spring and spring plate are aligned. Now install the center nut and un compress the spring. |
Step 9. You now have a complete Strut Assembly that is ready for installation. Install in reverse order of removal. |
If you need vehicle specification strut replacement procedures that can be accessed online, get an online manual specific to your car's year, make and model. |
