Ford CODE 18: IDM circuit failure or SPOUT circuit grounded
The computer sends out a timing advance correction to the ICM over the SPOUT wire and then looks for the change on the IDM wire.
IDM - Ignition Diagnostic Monitor
SPOUT - Spark Output Signal from EEC/PCM
ICM - Ignition Control Module
You might check the ECT or the IAT sensor for your problem.
Also check the SPOUT/IDM wire going to ground.
ECT - Engine Coolant Temperature sensor and it has two wires on it.
IAT - Intake Air Temp
IDM (feedback) is a Dark Green with a Yellow stripe wire on the distributor connector.
IDM is pin 4 on the 60 pin ECM connector.
Ford trouble code 18
divider
Top Categories
Serpentine Belt Routing Diagrams
Ask a Mechanic
Free Insurance Quotes
Car Owners Manuals
Auto Wiring Diagrams
Auto Repair Manuals
Auto Repair Estimates
Hybrid Cars
Nut & Bolt Measuring Charts
Mechanic's Lien Form
Top Repair
Air Conditioning Troubleshooting
Blown Head Gasket
Brakes
Auto Repair
Engine Overheating
Engine Sensors
Struts
Hub Bearings
No Start Diagnostics
Transmission
