If you run into a problem with your car, you may want to take a moment and check a few things out for yourself and to help answer any questions your mechanic is likely to ask when you drop it off for service. This can save you time and money in the long run. And who knows, you might find that you may be able to fix it yourself and save even more.
2. Now that you have figured out what the issue is you need to repair, you can continue to simplify that area. Lets take "Noise" for example. The car makes noise. Ask yourself questions, Say "Self..."
3. Tap yourself on the head a few times and think for a moment. You have a Roaring Noise that occurs while driving that gets louder and quieter when turning and is coming from the left front of the vehicle and has nothing to do with the brakes.
Congratulations! You have now discovered the Left Front Hub Bearing Assembly needs to be replaced.
If you need auto repair manual procedure to perform the repair right now you can purchase an online repair manual and have access now for just $19.95. Includes your vehicles wiring diagrams, TSB's, Auto Repair Procedures, Maintenance schedules and more. You can also ask an auto repair question Now
