If you do not have power to the relay, but you do have power to the fuse. Check to see if it has a rollover/cutoff switch. It should be listed in the owners manual with the location.(usually inside passenger kick panel).
If you need a wiring diagram just follow the wiring diagrams link above and follow the instructions.
