Trouble Codes › KIA OBDI Trouble Codes
Full list of OBD I Diagnostic Trouble Codes for your KIA. If your KIA Check engine light is on you may have a serious problem. Scan your codes and follow the chart to determine what the code means. Some shops will scan your codes for free. Autozone is one place that will give you the code number.
How to Read Trouble Codes for Pre 1996 OBD I KIA
  1. To enter self-diagnostics, connect a jumper wire between GND and ENG TEST terminals at the Data Link Connector (DLC). See diagram below. The DLC is located at the center rear of the engine compartment.
  2. On all models, turn ignition on (engine off). Observe the MIL and identify the trouble codes. Perform appropriate diagnostic tests. See Trouble Code Identification below.
KIA Trouble Code Test Port Diagram
KIA Trouble Code Identification
Code
System Affected
Probable Cause
02
No Ne-Signal
Distributor
03
No G-Signal
Distributor
08
Mass Airflow Sensor Circuit
Open Or Short Circuit
09
Engine Coolant Temperature Sensor
10
Intake Air Temp. Sensor Circuit
12
Throttle Position Sensor Circuit
14
Atmospheric Pressure Sensor Circuit
15
Oxygen Sensor
Sensor output voltage stays at less than .55 volt with engine speed at 1500 RPM
17
Feedback System
Sensor output unchanged 50 seconds after engine speed exceeds 1500 RPM
25
Pressure Regulator Solenoid Valve Circuit
26
Purge Control Solenoid Valve Circuit
34
Idle Speed Control Solenoid Valve Circuit
TO CLEAR THE CODES:
  1. Turn ignition off
  2. Disconnect negative battery cable for a minimum of 20 seconds
  3. Codes are now cleared
  4. Reconnect battery cable
NOTE: When power is disconnected to the ECM to clear codes, computer memory will be erased. A change in vehicle performance and driveability may be noted while the ECM re-calibrates for current driving conditions.
KIA Trouble Codes
divider
