Trouble CodesToyota Trouble CodesToyota OBDI Trouble Codes
Full list of Toyota OBD II Diagnostic Trouble Codes for your Vehicle. If your Check engine light is on you may have a serious problem. Scan your codes and follow the chart to determine what the code means. Some shops will scan your codes for free. Autozone is one place that will give you the code number. If you need personal assistance you can ask a question 24/7 from a PAID third party site and Ask A Mecahnic Now or you can ask for FREE by following the Questions Tab above and our experts will help you with your Toyota problems.
Toyota Specific Trouble Codes
P1100 - BARO Sensor Circuit
P1120 - Accelerator Pedal Position Sensor Circuit
P1121 - Accelerator Pedal Position Sensor Range/Performance Problem
P1125 - Throttle Control Motor Circuit
P1126 - Magnetic Clutch Circuit
P1127 - ETCS Actuator Power Source Circuit
P1128 - Throttle Control Motor Lock
P1129 - Electric Throttle Control System
P1130 - Air/Fuel Sensor Circuit Range/Performance (Bank 1 Sensor 1)
P1133 - Air/Fuel Sensor Circuit Response (Bank 1 Sensor 1)
P1135 - Air/Fuel Sensor Heater Circuit Response (Bank 1 Sensor 1)
P1150 - Air/Fuel Sensor Circuit Range/Performance (Bank 1 Sensor 2)
P1153 - Air/Fuel Sensor Circuit Response (Bank 1 Sensor 2)
P1155 - Air/Fuel Sensor Heater Circuit (Bank 1 Sensor 2)
P1200 - Fuel Pump Relay Circuit
P1300 - Igniter Circuit Malfunction - No. 1
P1305 - Igniter Circuit Malfunction - No. 2
P1310 - Igniter Circuit Malfunction - No. 2
P1335 - No Crankshaft Position Sensor Signal - Engine Running
P1349 - VVT System
P1400 - Sub-Throttle Position Sensor
P1401 - Sub-Throttle Position Sensor Range/Performance Problem
P1405 - Turbo Pressure Sensor Circuit
P1406 - Turbo Pressure Sensor Range/Performance Problem
P1410 - EGR Valve Position Sensor Circuit Malfunction
P1411 - EGR Valve Position Sensor Circuit Range/Performance
P1500 - Starter Signal Circuit
P1510 - Boost Pressure Control Circuit
P1511 - Boost Pressure Low
P1512 - Boost Pressure High
P1520 - Stop Lamp Switch Signal Malfunction
P1565 - Cruise Control Main Switch Circuit
P1600 - ECM BATT Malfunction
P1605 - Knock Control CPU
P1630 - Traction Control System
P1633 - ECM
P1652 - Idle Air Control Valve Control Circuit
P1656 - OCV Circuit
P1658 - Wastegate Valve Control Circuit
P1661 - EGR Circuit
P1662 - EGR by-pass Valve Control Circuit
P1700 - Vehicle Speed Sensor "2" Circuit Fault
P1705 - Direct Clutch Speed Circuit Fault
P1765 - Linear Shift Solenoid Circuit Fault
P1780 - Park/Neutral Position Switch Malfunction (Only For A/T)
P1875 - 4WD Low Switch Circuit Malfunction
divider
Top Categories
Serpentine Belt Routing Diagrams
Ask a Mechanic
Free Insurance Quotes
Car Owners Manuals
Auto Wiring Diagrams
Auto Repair Manuals
Auto Repair Estimates
Hybrid Cars
Nut & Bolt Measuring Charts
Mechanic's Lien Form
Top Repair
Air Conditioning Troubleshooting
Blown Head Gasket
Brakes
Auto Repair
Engine Overheating
Engine Sensors
Struts
Hub Bearings
No Start Diagnostics
Transmission
