CODE 24 - VSS (Vehicle Speed Sensor)
Trouble Code 24 indicates that the Vehicle Speed Sensor (VSS) is reporting an abnormally low reading when other sensors indicate it should be higher.
If the code was logged when the vehicle was in motion, the following should be checked:
1) Defective or corroded VSS connections
2) Maladjusted TPS sensor. The TPS should read about 0.42 volts at closed throttle
3) Defective speedometer cable
4) Bad or missing speedo drive gear(s) in tail shaft housing of the transmission
5) Defective VSS
6) Defective ECM
