Trouble Codes › GM OBD Trouble Codes › GM Code 25
CODE 25 - Manifold Air Temperature Sensor
Trouble Code 25 indicates that the Manifold Air Temperature (MAT) sensor also known as the (IAT) Intake Air Temperature is reporting abnormally high readings. When the air is hot, the thermistor has a low resistance, which rises as the air temperature cools. High readings thus indicate a possible bad sensor or short in the MAT/IAT circuit.
  • MAT/IAT reading is > 275 deg F (135 deg C), and
  • the engine has been running for more than 16 seconds, and
  • the vehicle speed is > 40 MPH
Refer to the Code 25 description for typical sensor resistance values.
1) Defective MAT/IAT sensor
2) MAT/IAT signal shorted to ground or to sensor ground
3) Defective ECM
  Return to Chart
Chevy Trouble Codes
divider
