CODE 46- VATS System Fault
The ECM receives a signal from the Pass-Key module. When the correct signal is received, the ECM will allow the engine to start and run. Please review the RepairPal article on the GM Pass-Key Anti-theft systems for more information.
Symptoms
Common Causes
