Trouble Codes › GM OBD Trouble Codes › GM Code 52
CODE 52 - CALPAK Fault
Trouble Code 52 indicates that the ECM sensed a fault with the CALPACK. The CALPACK is a plug-in module separate from the PROM, that contains preset calibrations used by the system during "limp home" (backup) mode. The ECM continuously checks for its presence while power is applied.
  • the ECM does not sense the CALPACK
1) Incorrectly installed CALPACK module
2) Incorrect CALPACK module for this vehicle
3) Defective or incorrectly inserted PROM
4) Defective ECM
  Return to Chart
Chevy Trouble Codes
divider
