CODE 54 - Fuel Pump Circuit
The ECM monitors the voltage to the fuel pump from the fuel pump relay. If the voltage is below specification code 54 will set.
Symptoms
Common Causes
Trouble Code 54 is not used by the turbo cars. If this code does appear, it is probably due to a loose connection or bad ground. If a computer is connected to the car's ALDL connector when the code appears, check the computer cable connections.
