Home » Car Questions » 2000 Dodge Ram 1500 ABS Light on
Dodge Ram 1500
ABS light is on
My ABS light is on and I had the codes read. Was told I needed both front ABS Sensors. I replaced both sensors and the cleared codes. ABS light came back and said only the front right was working and the front left was bad. What could it be?
1 thought on “2000 Dodge Ram 1500 ABS Light on”
  1. 1. Could be a bad new sensor
    2. If the hub bearing is bad as the ring the sensor reads off of is inside the hub bearing(bad bearing)
    3. If the inside of the hub bearing is dirty, sometimes you can use brake wash to clean the ring.
