Home » Car Questions » 1989 mercedes
1989 mercedes
the odometer and heater dont work, why?
1 thought on “1989 mercedes”
  1. TRY THE CABLE AND SENDING UNIT IN TRANS ON THIS CAR THE PROBLEMS ARE NOT RELATED THE HEATER IS MOST LIKELY THE HEATER VALVE LOCATED AT THE REAR OF ENGINE COMPARTMENT IT HAS TWO HOSES BOTH 5/8 RUNNING OUT OF EACH SIDE WITH A VALVE AND CABLE ON THE UNIT VISIBLE. THIS IS WHERE YOU WILL FIND OUT IF THE VALVE IS BAD OR THE CABLE DO YOU LIVE IN SNOWY CONDITIONS? THIS IS COMMON AROUND THE NORTH.
