Home » Car Questions » 2004 Ford Expedition2004 Ford ExpeditionOctober 3, 2009November 10, 2017how to change the starter? Cannot remove top bolt from starter.Keywords:ExpeditionHow toStarter1 thought on “2004 Ford Expedition” Jaxer October 4, 2009 at 8:53 am If you need the procedure you can request it here: http://freeautomechanic.com/repairmanuals.htmlAssuming you are using the right socket size and the bolt is just to tight. It sometimes requires a torch to heat the bolt and then it will loosen.Comments are closed.previous2002 Nissan Altima – Throttle Bodynext2000 Chrysler Sebring jxi
