Home » Car Questions » 2000 Ford Ranger clutch problems
I have a 2000 ford ranger 5 speed and my clutch is acting up. I have my clutch pushed all the way in and I can not shift
TSB 01-24-1 Clutch Pedal Stays on Floor – Not Able to Disengage Clutch
2 thoughts on “2000 Ford Ranger clutch problems”
  1. What you described is a classic description of a failed Cluch Master Cylinder , the clutch itself is probably just fine. Have the Clutch Master Cylinder Replaced and you should be back to normal. The internal seals go bad and allow fluid to flow past instead of compress. Very similar to a hydraulic brake master cylinder.
