1996 ford ranger oil pan rusted through. So I used JB Weld but still leaks. Replacement estimate is 1000 dollars. Is there any cheaper way to fix?
Yes. Do it yourself. Replace the entire oil pan.
Oil Pan, Replace
On 4WD models, it is necessary to remove engine before removing oil pan. |
FIND A REDNECK AND PAY THEM TO TAKE THE MOTOR MOUNTS LOOSE AND JACK THE ENGINE UP IN THE TRUCK AND REPLACE THE OIL PAN THE CHEAPEST AND EASY FIX NOTHING WILL HOLD THE OIL IN THAT YOU CAN TRUST, BUT A WELDER. THATS NOT WORTH THE TROUBLE.
Go to a “Pick-a-Part” or Ecology junk yard or ect.. and buy a pan or buy a new pan from dealer or online. Get a manual “Chilton” for your year and model of vehicle and change the pan yourself. You can go to local library and read a manual and make a copy, if you don’t want to buy one. Changing a pan is easy, you just have to drain oil, have tools, have new pan, have enough new oil, new gasket, & know what to do. A friend maybe can help. Good-Luck!!
