Home » Car Questions » No reverse on ’92 Toyota Camry
My ’92 Camry with auto transmission wont reverse. Actually, it will reverse but only in the morning the first time I put in gear, after that, goes into gear but wont move. It doesnt leak trans fluid or slip gears, just wont go backwards! What could that be?
1 thought on “No reverse on ’92 Toyota Camry”
  1. It could be a failing reverse solenoid or stuck/sticky valve. Either way it is internal as long as it is full of fluid. If the fluid is full and dark in color than you will need a complete rebuild.
