Home » Car Questions » SAAB 2001 shuts down in “midflight”
My 2001 SAAB 9.5 shuts down in the middle of driving….we have changed the alternator and battery because it did not want to start…and needed jumped all the time….now, if it feels like it, it will start, but after driving it for a while, all the dashboard lights turn on, and it just shuts off in the middle of driving….if it sits a couple hours, it will start back up again…sometimes when the key is turned, it just ticks, ticcks, ticks…..sometimes it will start…..HELP !!!! could the relay box be causing this problem?
1 thought on “SAAB 2001 shuts down in “midflight””
  1. The tick tick tick is usually an indication of a bad battery OR LOOSE/CORRODED CONNECTIONS. Since you have a new battery, the cables that come from the battery my be corroded internally or bad connections at either the battery or stater/ground connections.
    One test you can try: with the engine running, do the “wiggle test” grab different wires and one at a time wiggle them to see if the engine dies. If you find one that does then your in luck. Trace its connections and make the correct repairs.
