Home » Car Questions » whats wrong with my truck
theres blue smoke from the engine and the exhausted it will run for like 30sec it shakes so bad
3 thoughts on “whats wrong with my truck”
  1. Blue smoke is created by the vehicles engine oil entering a cylinder and being burned along with the Air/Fuel mixture. A small amount of oil leaking into a cylinder will create blue smoke out the tailpipe. Blue smoke is more often and issue in older or higher mileage vehicles.
    Sometimes using a thicker oil can help, but in most cases replacing the failed gaskets and seals is the best way to insure the issue is fixed.
    http://www.freeautoanswers.com/bluesmoke.html
  2. BLUE SMOKE IS CAUSED BY PISTON RINGS FAILING OR FAILED YOU CAN PULL THE PLUGS OUT AND DO A COMP. TEST FOR YOUR BAD CLYINDER OR CLYINDERS. YOU NEED A NEW MOTOR OR A REBULILD.
  3. Sounds to me like you blew a head gasket. Replace gasket make sure theres no water in the plugs do so right away, or you will be needing a new engine.
