Blue smoke is created by the vehicles engine oil entering a cylinder and being burned along with the Air/Fuel mixture. A small amount of oil leaking into a cylinder will create blue smoke out the tailpipe. Blue smoke is more often and issue in older or higher mileage vehicles.
Sometimes using a thicker oil can help, but in most cases replacing the failed gaskets and seals is the best way to insure the issue is fixed. http://www.freeautoanswers.com/bluesmoke.html
pdt81
BLUE SMOKE IS CAUSED BY PISTON RINGS FAILING OR FAILED YOU CAN PULL THE PLUGS OUT AND DO A COMP. TEST FOR YOUR BAD CLYINDER OR CLYINDERS. YOU NEED A NEW MOTOR OR A REBULILD.
jcastle
Sounds to me like you blew a head gasket. Replace gasket make sure theres no water in the plugs do so right away, or you will be needing a new engine.
