I need to know where the pcv valve tube connects on my monte carlo. I know it connects to the throttle body and the valve cover but i dont know where the last connection is. a diagram would be much appreciated
1996 Monte Carlo 3.1 V6 pcv valve tube
There is a connection at the throttle body, hard plstic and runs tot he back side of the engine and connects to the pcv valve in the valve cover and is located just under the coil pack assembly.
If you need diagrams:
http://www.freeautomechanic.com/repairmanuals.html
