van starts fine, drive about 10 miles, check engine light comes on. After I shut it off takes forever to start again. have already replaced fuel filter,fuel pump relay, and throttle body sensor. What else can it be? the flash code is 44
92 chevy g20 van 350 wont restart after warm up
Keywords:Check Engine Light
What are the check engine light codes? You can check the codes for free, here is how: http://www.freeautomechanic.com/diagnostictroblecodes5.html
If I had to guess out of the blew… 99% sure it is your ignition module in the distributor.
Ignition module works for me — if it gets too hot, it makes it tough to start. There should be a heat conducting gel under the module, I have no idea how long it is supposed to last, but it would be a quick and cheap fix if all you had to do was clean off the old gel and add some new stuff.
