1994 Cutlass Supreme – Hello I need An ANSWER PLEASE
I currently Own a 1994 Cutlass Supreme, it has a 3.4L V6 DOHC 24 Valve FWD Gm Engine, I was wondering what other engines can i replace it with and will work without a lot of work needed to be done, please answer me back Thank You
1 thought on “1994 Cutlass Supreme – Hello I need An ANSWER PLEASE”
  1. I would recommend the same engine as if you change it , you will need to change out the computer and electrical wiring harness. Possibly the exhaust and fuel pump will have to change as well.
    If you want to spend lots of time and money you can put different engines in it like a 2.5L 4 cylinder but I do not recommend it.
