HAVE A (1987) DODGE DAKOTA>< NEW ALTERNATOR><NEW VOLTAGE REGULATOR><NEW BATTERY STILL WILL NOT CHARGE >< THANK YOU >< NEW STARTER TO !
truck will not charge
Keywords:No Start
Make sure you have battery voltage at both wires on the plug or it will not charge.
http://www.freeautomechanic.com/alternator.html
thank you jaxer will give it a try !
did you check the fuse for the altenator and check to make sure your ground on the engine is good
