Home » Car Questions » 2002 chevy blazer 4×4 4.3 vortec engine
it take 15 mins to put in 5.00 dollars with of gas there is no vent line that runs along side fill tube i have disconnected all lines to charcoal filter didnt make a differants what is wrong.
1 thought on “2002 chevy blazer 4×4 4.3 vortec engine”
  1. The vent tube is the outside of the fill hose. On the inside is another hose that is the fill tube and inside of that fill hose is a check ball to help prevent gas fume leaks and and added benefit, to keep people from stealing your gas. If the inside hose is punctured it may cause the issue you are having.
    You can try using a wooden dowel rod and make sure there are no obstruction in the way inside the fill neck. (you know, to make sure someone didn’t put something in there)
