Speedometer stuck at 0 mph. Transmission only has 2nd forward gear(reverseis fine). Dash gear indicator boxes on all gears. Check engine light indicates codes P0500(no VSS signal) and P1698(no CDD message from TCM). replaced input/output speed sensors no change. Please help!
Home » Car Questions » Speedometer, tranny only 2nd gear, dash gear indicator problems
It may be useful to indicate the Year Make and Model of the vehicle with the issue……..
