What are the steps I need to follow to replace the turn signal / wiper switch arm? FYI-A mechanic already determined it was needing to be replaced. My Lo and Intermittent settings were no longer working, only the Hi setting. I have a near useless Haynes Repair Manual and it doesn’t show a thing on this.
Thanks,
John
Replacing the “multi-function switch” isn’t difficult at all.
1) Remove the steering column lower cover retaining bolts from underneath and this should allow access to the two retaining bolts for the multi-function switch.
2) Remove the bolts and disconnect the electrical plug in.
3) Install in reverse order.
