i have a 2003 suburban and when i shut off the key the radio stays on windows still work the PRND123 lights stay on and also the battery light stays on even with the doors open
In normal situation the all function will work until the door is openned and the computer recieves a signal from the door latch switch to shut off power. Since this isn’t happening, I would think either the door switch is sticking/worn or wiring from the switch.
but even with the doors closed should the little battery light b on????
i unplugged the battery over night and everything worked like it should….then today it was saying the back right door was ajar and when i parked it the radio and battery light stayed on when i shut the truck off. and everything shut off when i turned on the wiper switch…..im lost on this
