I have a 95 silverado it has the 5.7l. the truck was left to me from a relative. its always been well taken care of. well i let it sit for three months over the winter without driving it. i did go out and start it once in a while. now i have been driving it. when i go to take off from a dead stop it spits and sputters and sometimes stalls. i can keep it running if i put one foot on the brake and give it a little gas while stopped. once the truck takes off it runs fine it only does it when i stop. Here today it actually stalled twice. to get it restarted i had to put the gas pedal all the way down before it started and when it did a little black smoke came out the exhaust but then once i was going everything was ok. any help would be appreciated. could it be the plugs?
Home » Car Questions » 95 chevy silverado stalls when leaving a complete stop
Keywords:ru
Performing a complete tune up wouldn’t hurt but most likely a combination of old gas and a sticking IAC is the problem. Once it is warmed up it probably runs fine?
You can also check for engine codes yourself, Here is how: http://www.freeautomechanic.com/diagnostictroblecodes5.html
Most likely just needs driven and some good old high test octane to help clear it up a little.
