blinkers, tail lights & brakelights went out one by one. tried wiggle test with no luck. getting no power to rear of car. keeps blowing fuse for brakelights. any ideas?
Keywords:Electrical
The only reason a fuse would blow is if it is shorted. So this means the positive side of the circuit has come in contact with a negative(ground). You will need to check all the wiring in this curcuit until you find and fix the electrical problem.
Testiing with a Multi-meter
