91 accord stalls while driving after RPM begins surging. Car takes several minutes to restart, sounding like it is out of gas each time I try to start. No engine check lights yet. PLEASE HELP
Most common problem for this issue with this vehicles is the Distributor Assy.
A quick test to make sure it is not fuel related would be to shoot some starting fluid in the air cleaner the next time it doesn’t want to run… if it starts right up and runs good on the starting fluid, then you make have a fuel pump going bad. In this case you will need a fuel pump.
