Home » Car Questions » How to Remove the Caliper
How do you remove the brake-caliper guide pins on a 1990 Ford Ranger 2.9L?
1 thought on “How to Remove the Caliper”
  1. You take a Flat screw driver and hit on the outer edge of the guide pins so they move just under the retaining lip. Do this on top and bottom of the guide until it is pinched inside and knock it the rest of the way out.
