Hi
I have a 2008 fusion SEL. I have always jacked the car from the Ford recommended jacking points using a piece of wood with a slot to fit the flange edge along with my floor jack. I’ve seen shops lift the car from different points, including under the rear control arm. Is that an acceptable place ? Can anyone recommend good places to jack the car and place jack stands under.
Thanks
R Walker
It is best to follow the manufacturers recommended procedures for jacking the vehicle.
Jacking the vehicle up by the control arms and placing the jack stands under the jacking points would be the most stable.
