All electricals seized up at once, the Steering, shift, AC, Engine Fan, ABS, Trans?, Windows, power sunroof, radio works though, Scary, had been having that steering noise, TSB issued by Toyota, Dealer does not have a clue, any thoughts. Once a computer goes 1,000’s to fix, Don’t want a Band aid from Toyota?
Keywords:Electrical
If all electrical has gone this is usually a bad battery or alternator.
If the battery and alternator are good, start narrowing down the circuit. Start with checking the fuses. If all are fine, Get your hands on a wiring diagram and see what is common to all these electronics that have failed. Might just be a bad ground.
http://www.freeautomechanic.com/wiringdiagrams.html
