Hi,
There is a connector on the right rail at the bottom of the drivers seat. My connector is disconnected and my “airbag disconnected” waring light is illuminated.
I had to pull the seat to get to the connector. My problem is I can’t find a receptor for the connection. What does it plug into?
Thanks
When driving the gauges gyrate and the dash lights flicker. Under acceleration the headlights dim. After some driving distance, the…
Fog Light Replacement Unplug electrical connector from fog light assembly Remove 13mm retaining nut and washers from fog light under…
If you haven't heard already, GMThe agency said that without the warning light, a vehicle may be driven with low…
https://youtu.be/Svf620OlWF0 This video is the rear section of the frame kit installation. https://youtu.be/Z7uBahE6hoY This video is of the center section…
Hi, just following up on 02 Caravan: I was scanning with the newest up date and not the vin# so…
View Comments
A scan tool is required to determine why the light is illuminated.
The connector under the seat may not need to connect to anything. Sometimes seat belts have a switch inside the receptor to make sure it is snapped in or it will shut off the air bag.
If any part of the air bag system fails, the light on the dash will illuminate.
