wiper wont worked,change the muiltfunction switch and fuses and relay help
Home » Car Questions » from GARY on1996 FORD TUARUS WIPERS wont WORk
Keywords:wiper motor
Check for power at the wiper motor. If you have power at the motor and no operation, replace the wiper motor.
Testing with a Multi-Meter
WHEN CHECKING THE WIPER MOTOR AGAIN I FOUND A GROUND WIRE LOOSE THANK YOU FOR YOUR HELP!!!
