Home » Car Questions » traction control
traction control
I have ford fairmont ghia AU and trction control light stays on also ABS light what can be done
1 thought on “traction control”
  1. Anytime the ABS has an issue the traction control is turned off automatically. So, fix the ABS and the traction Control light will go out as well.
    You will need a scan tool to determine the ABS Codes in order to discover what is causing the issue.
