THE CAR STARTS AND DRIVES AND THEN DIES, IT STARTS AGAIN AND DRIVES A LITTLE MORE AND THEN DIES AGAIN, THEN IT JUST WON’T START AT ALL FOR A LONG WHILE. I REPLACED THE FUEL PUMP AND IT STILL DOES IT.
Keywords:WHAT COULD BE CAUSING THIS.
First thing to do is determine if it is missing fuel of spark or both when it will not start.
If it is just missing fuel, concentrate on this area.
If it is missing Spark, it is most likely a ignitiion module(most common)
If it is missing both, could be a bad crank sensor or computer.
You can scan the engine codes yourself and see if there are any codes stored that might give a hint as to what is triggering the probelm. Here is how: http://www.freeautomechanic.com/diagnostictroblecodes5.html
@SvenX13No way. The Fiesta is aylwas placed below the focus in every market where they coexist.
