why does my cars idle fluctuate speratic it’s a manuel and i already swapped the ilde air control valve but it was a salvaged one. anyway suggestions on what it could be would be greatly appreciated
Keywords:Rough Idle
A vacuum leak can sometimes cause this as it makes the Idle Air Control Search constantly. Another cause can be build up inside the throttle body around where the butterfly seats in the throttle body. Clean it with solvent and a rag with the engine off.
i’ll try that i actually figured out that if my wheels are turned tight either way that it stops and as soon as i turn my tires straight it starts agian
