Home » Car Questions » steering fluid leak
steering fluid leak
I have just bought a 2002 dodge van , and noticed steering fluid in the driveway .. I checked it and it was empty, I refilled it and it was empty again this morning … I havent driven it since i noticed the leak … could it be just a hose ?
1 thought on “steering fluid leak”
  1. Sure it could be anything at this point. Fill the fluid level and run the engine and have someone turn the steering wheel back and forth and you should be able to see it coming out or spraying out if a high pressure line is leaking.
